[fusion-trac] #317: Map doesn't display as the selected base layers after selecting Map widget.
Fusion trac_fusion at osgeo.org
Fri Nov 6 01:51:06 EST 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1273019  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Open one flexible web layout with commercial layers.
 2. Click Map Widget and select the default map.
 3. Switch the commercial layers by external provider.
 Results:
 Nothing changed.
 Expected results:
 The base layer should be consistent with the one selected.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/317>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
