[fusion-trac] #321: Theme: The object with biggest value doesn't display correctly with Equal Distribution
Fusion trac_fusion at osgeo.org
Wed Nov 11 22:02:30 EST 2009
Distribution
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1276823  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Open one flexible web layout with Polygon layer by IE(one SDF file
 polygon).
 2. Theme-> Select FeatID, and Equal as Distribution rule -> Apply.
 Results: The object, which FeatId is the biggest, doesn't display as Theme
 rule.
 Expected results: Each object should display as rule.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/321>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
