[fusion-trac] #322: Query: Behavior of Clear and Checkbox for Spatial Filter is not consistent
Fusion trac_fusion at osgeo.org
Wed Nov 11 22:04:03 EST 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1276830  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Open one flexible web layout by IE.
 2. Query
 3. Check Spatial Filter -> Draw Rectangle -> Clear
 4. Check Spatial Filter -> Draw Rectangle -> Uncheck Spatial Filter
 Results:
 After Step3, the check box of Spatial Filter is unchecked, the rectangle
 is cleared.
 After Step4, the check box  of Spatial Filter is unchecked, but the
 rectangle is still be there.
 Expected results:
 Once Uncheck Spatial Filter, the rectangle should be cleared also.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/322>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
