[fusion-trac] #323: Theme: Individual rule for Numeric property is disordered.
Fusion trac_fusion at osgeo.org
Wed Nov 11 22:06:04 EST 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1276835  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Open one flexible web layout with Polygon data.
 2. Theme->Select FeatId, Individual as Distribution rule -> Apply
 Results:
 Please refer to the attached png file, the rule is disordered and not
 based on the FeatID value.
 If using one String property, it looks correct.
 Expected results;
 The rule should refer to the value of FeatID.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/323>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
