[fusion-trac] #324: Theme widget doesn't work because layer
definition schema definition
Fusion
trac_fusion at osgeo.org
Thu Nov 12 03:57:45 EST 2009
#324: Theme widget doesn't work because layer definition schema definition
Reporter: christinebao | Owner: Christine Bao
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: Theme | External_id: 1276805
State: New | Browser: All
Os: All |
Comment (by christinebao):
'''Tech diagnosis:'''
The key point is the original layer definition. Please use MapAgent /
GetResourceContent to check the layer definitioins. Please pay special
attention to the element <AreaTypeStyle>.[[BR]]
In layer1.LayerDefinition, it's:[[BR]]
<AreaTypeStyle>
<AreaRule>
</AreaRule>
<ShowInLegend>true</ShowInLegend>
</AreaTypeStyle>
[[BR]]
And in layer2.LayerDefinition it's:[[BR]]
<AreaTypeStyle>
<AreaRule>
</AreaRule>
</AreaTypeStyle>
[[BR]]
The difference is layer1.LayerDefinition contains additional element
<ShowInLegend> besides <AreaRule>, while layer2.LayerDefinition doesn't.
'''How this defect happens?'''[[BR]]
The theme widget works in this way:[[BR]]
1. Remove the existing <AreaRule>.[[BR]]
2. Create a series of new <AreaRule> based on user's setting.[[BR]]
3. Append the new <AreaRule> to <AreaTypeStyle>.
LayerDefinition-1.3.0.xsd defines <AreaTypeStyle> in this way:[[BR]]
<xs:complexType name="AreaTypeStyleType">
<xs:annotation>
<xs:documentation>Style specification of a polygon geometry
type.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="AreaRule" type="AreaRuleType"
maxOccurs="unbounded">
<xs:annotation>
<xs:documentation>Rules to define a theme.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="ShowInLegend" type="xs:boolean" default="true"
minOccurs="0"/>
<xs:element name="ExtendedData1" type="ExtendedDataType"
minOccurs="0"/>
</xs:sequence>
</xs:complexType>
[[BR]]
It requires <AreaRule> must be ahead of <ShowInLegend>.
In scenario 1, because new <AreaRule> is appended to <AreaTypeStyle>, and
it goes after <ShowInLegend>, an exception throws out when saving to DB
XML. [[BR]]
In scenario 2, the above problem doesn't exist, so it works.
'''How to fix?'''[[BR]]
theme.php function ApplyTheme(): should decide whether <AreaTypeStyle> has
additional element besides <AreaRule>. If yes, the new <AreaRule> should
insert into first node. If no the new <AreaRule> should be appended.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/324#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
