[fusion-trac] #327: Query: The matched objects excluded by layer filter are listed in Query result.
Fusion trac_fusion at osgeo.org
Fri Nov 13 00:29:32 EST 2009
result.
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1277730  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Load the attached package.
 2. Open the flexible web layout by IE.
 3. Query -> Property Filter -> Autogenerated_SDF_ID, Equal, 11 -> Execute
 query
 Results:
 One record named "11" are listed in Results panel.
 Expected results:
 Query should do against the layer but not the data source.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/327>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
