[fusion-trac] #319: Issues with Multiple Maps Within a MapGroup
Fusion trac_fusion at osgeo.org
Fri Nov 13 16:16:28 EST 2009
 Reporter:  tnolte                       |         Owner:  tnolte
     Type:  defect                       |        Status:  assigned
 Priority:  P1                           |     Milestone:  2.0
Component:  MapServer                    |       Version:  2.0 - beta
 Severity:  Major                        |    Resolution:
 Keywords:  mapserver, mapgroup, legend  |   External_id:
    State:  Analysis Requested           |       Browser:  All
       Os:  All                          |
Changes (by tnolte):
  * state:  Review => Analysis Requested
Comment:
 Another issue related to Multiple Maps was the Query/Selection
 functionality. I was able to update the relevant code in
 SelectionPanel.js, layers/MapServer/php/Query.php, and
 layers/MapServer/php/Selection.php. I was able to get this working for
 multiple MapServer maps, however in reverting my ApplicationDefinition
 back to a single MapServer map the MapServer cgi is reporting
 "msQueryByShape(): Search returned no results. No matching record(s)
 found." when loading the map image using the created query.qy file. So
 Query.php is working as it should and the Selection Panel is even loading
 up the query results. The query file looks exactly the same whether
 generated with a single combined mapfile or broken out into multiple
 stacked mapfiles. My development server is running the latest MapServer
 5.6 beta release so I'm not sure if this is somehow the cause of my
 problems. Seems like more of a problem with MapServer not Fusion.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/319#comment:6>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
