[fusion-trac] #300: Maps with commercial layers failed to
display in supported browsers except IE.
Fusion
trac_fusion at osgeo.org
Tue Nov 17 11:20:24 EST 2009
#300: Maps with commercial layers failed to display in supported browsers except
IE.
Reporter: jennyhe | Owner: zjames
Type: defect | Status: assigned
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1257754
State: Approved | Browser: All
Os: All |
Comment (by pagameba):
I've committed a change to this code that fixes a javascript error when
MapGuide is not present (mapserver users). The call to createSessionId()
has been moved inside appDefUrl and extra tests have been added to limit
this behaviour to application definitions being loaded from Library:// or
Session://.
Please confirm this does not break anything for you as I have only tested
without mapguide.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/300#comment:5>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
