[fusion-trac] #334: Buffer failed to work on web layout with consumer map.
Fusion trac_fusion at osgeo.org
Thu Nov 19 03:56:22 EST 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1280021  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA
 Steps:
 1. Open one flexible web layout with consumer map.
 2. Buffer -> Select Object -> Refresh layer information -> Set the
 appropriate buffer distance -> Done.
 Results:
 1. Consumer maps disappeared with one warning message in IE.
 2. Buffer doesn't created successfully but the legend displayed.
 3. Once uncheck the layer in Legend panel, nothing happened.
 Expected results:
 Buffer should work correctly.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/334>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
