[fusion-trac] #321: Theme: The object with biggest value
doesn't display correctly with Equal Distribution
Fusion
trac_fusion at osgeo.org
Mon Nov 23 02:29:20 EST 2009
#321: Theme: The object with biggest value doesn't display correctly with Equal
Distribution
Reporter: jennyhe | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1276823
State: New | Browser: All
Os: All |
Changes (by christinebao):
* cc: arthur.liu at autodesk.com (added)
Comment:
Tech diagnosis:
The index of last element is not correct. Because the while loop is from 0
to < count($values)-1, the last one should be $count($values)-2. Fix it by
patch http://trac.osgeo.org/fusion/attachment/ticket/321/Range.patch.
Please review. Thank you.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/321#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
