[fusion-trac] #320: Two Layers with the same name could be created in the Redline Panel
Fusion trac_fusion at osgeo.org
Tue Nov 24 05:06:39 EST 2009
 Reporter:  tenswell  |         Owner:  madair
     Type:  defect    |        Status:  new
 Priority:  P3        |     Milestone:  Future
Component:  Widgets   |       Version:  1.1.1
 Severity:  Major     |    Resolution:
 Keywords:            |   External_id:  1276516
    State:  New       |       Browser:  All
       Os:  All       |
Comment (by christinebao):
 The layer names are not for logic control: when add/rename layer name,
 they can be duplicated and it doesn't affect the functions. Generally the
 layer name is just for organizing digitalizations, user can put any
 reasonable name even if (s)he choose duplicated names.
 However it's not good for the default new layer name duplicated with those
 existing, so SWD and QA agree to fix "New Layer" function in this way: the
 default new layer name should be unique - there is no furthur requirement
 about how to define the name, for example, if existing name is "Digitizing
 layer 1", "Digitizing layer 2", the default name could be "Digitizing
 layer 0" or "Digitizing layer 3", as far as it's different from the
 existing.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/320#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
