[fusion-trac] #336: Selection Panel: Nothing shown in the panel
after select object in map with consumer maps.
Fusion
trac_fusion at osgeo.org
Thu Nov 26 10:35:17 EST 2009
#336: Selection Panel: Nothing shown in the panel after select object in map with
consumer maps.
Reporter: jennyhe | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.1
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1280026
State: New | Browser: All
Os: All |
Changes (by madair):
* version: 1.1.1 => SVN
* milestone: Future => 2.1
Comment:
the patch looks fine, it shouldn't break anything in any case. Assuming
it has been tested and fixes the issue, I would recommend applying it.
It would make testing and debugging these issues if the
ApplicationDefinition file (and using the Sheboygan data if at all
possible) was attached to tickets.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/336#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
