[fusion-trac] #338: Map returned to the default commercial layer after theme operation
Fusion trac_fusion at osgeo.org
Thu Nov 26 21:20:20 EST 2009
 Reporter:  liuar    |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  1.1.1
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:  1272741
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by liuar):
 That's because those operation like theme and buffer will refresh or
 reload the map, which will invoke setDefaultBasemap method  in
 BasemapSwitcher. So the default commercia layer will be set to baselayer
 again.
 There's a solution, added a event named MAP_MapGroupLoaded and
 setDefaultBasemap will react to this event rather than MapLoaded.
 MAP_MapGroupLoaded event will be fired when the whole map group is loaded.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/338#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
