[fusion-trac] #289: Dynamic loading of scripts for commercial map layer
Fusion trac_fusion at osgeo.org
Thu Sep 17 09:56:00 EDT 2009
 Reporter:  liuar        |         Owner:  zjames
     Type:  enhancement  |        Status:  assigned
 Priority:  P2           |     Milestone:  Future
Component:  Core         |       Version:  1.1.1
 Severity:  Major        |    Resolution:
 Keywords:               |   External_id:
    State:  New          |       Browser:  All
       Os:  All          |
Changes (by zjames):
  * owner:  liuar => zjames
  * status:  new => assigned
Comment:
 Arthur,
 We reviewed the patch and unfortunately it needs some modification before
 we can put it in trunk because it makes an assumption that will break many
 applications. If the ApplicationDefinition is not stored in the repository
 or the Fusion application uses MapServer instead of MapGuide, this patch
 will cause a failure.
 If you can make modifications so that the addition is entirely skipped in
 those cases, then we can apply it.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/289#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
