[fusion-trac] #69: Language determination by Fusion.
Fusion trac_fusion at osgeo.org
Mon Sep 28 14:49:31 EDT 2009
 Reporter:  tgudmu     |         Owner:  madair
     Type:  defect     |        Status:  assigned
 Priority:  P2         |     Milestone:  2.0
Component:  Core       |       Version:  SVN
 Severity:  Minor      |    Resolution:
 Keywords:             |   External_id:
    State:  Analysing  |       Browser:  All
       Os:  All        |
Changes (by madair):
  * version:  1.0.6 => SVN
  * browser:  Firefox 2 => All
Comment:
 this is doable for 2.0 with the caveats:
 - not doable if the map is using commercial layers only because there
 isn't necessarily any AJAX calls made to the server (MapGuide and
 MapServer both have a CreateSession.php interface that can be used for
 this
 - it would probably have to set it to the first lang code in the list, not
 do any fancy language setting based on the preferences in the list.
 (e.g. my default IE accept-language string is: "en-ca,en-
 us;q=0.8,fr;q=0.5,fr-ca;q=0.3", this would set language to en-CA if
 available, otherwise en.
 Some parts of the page have already been rendered by the time
 CreateSession is called and may require a redraw.
 comments?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/69#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
