[fusion-trac] #379: Normal layer with consume maps failed to
display in Overview map wdiget
Fusion
trac_fusion at osgeo.org
Mon Apr 12 12:48:26 EDT 2010
#379: Normal layer with consume maps failed to display in Overview map wdiget
Reporter: jennyhe | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Critical | Resolution: fixed
Keywords: | External_id: 1313287
State: New | Browser: All
Os: All |
Changes (by chrisclaydon):
* status: assigned => closed
* resolution: => fixed
Comment:
The patch was reviewed by Mike Adair, and submitted with the following
revision:
http://trac.osgeo.org/fusion/changeset/2139
The changes are actually pretty minor - I've moved the code that creates
the Fusion layer object from the initializeWidget method into the
mapWidgetLoaded method. This preserves the intent of changeset 2068, which
seeks to re-initialize the overview when the main map is reloaded, but
enforces that the underlying map definition has loaded before attempting
to create an OpenLayers layer that corresponds to it.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/379#comment:5>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
