[fusion-trac] #393: Exception in FDO component when using
feature information (Digitize Polygon)
Fusion
trac_fusion at osgeo.org
Thu Apr 22 14:11:41 EDT 2010
#393: Exception in FDO component when using feature information (Digitize
Polygon)
Reporter: liuar | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1313209
State: New | Browser: All
Os: All |
Comment (by chrisclaydon):
Could you do it like this instead, so that we don't duplicate points
unnecessarily if the handler is ever fixed to return a closed polygon?:
function OnPolyonDigitized(polygon) {
var points = [];
for (var i = 0; i < polygon.Count; i++) {
points.push(polygon.Point(i).X+' '+polygon.Point(i).Y);
// Close the polygon if it isn't already closed
if(polygon.Point(0).X != polygon.Point(polygon.Count - 1).X ||
polygon.Point(0).Y != polygon.Point(polygon.Count - 1).Y) {
points.push(polygon.Point(0).X+' '+polygon.Point(0).Y);
var geomText = 'POLYGON(('+points.join(',')+'))';
SetSpatialFilter(geomText);
Ticket URL: <http://trac.osgeo.org/fusion/ticket/393#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
