[fusion-trac] #401: The meaning of null CS for a MapGuide map is not compatible with that of null CS of Map Widget
Fusion trac_fusion at osgeo.org
Thu Jul 29 05:08:07 EDT 2010
   Reporter:  sparkliu  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P3        |   Milestone:  Future
  Component:  MapGuide  |     Version:  SVN
   Severity:  Major     |    Keywords:  Null CS
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 In MapGuide, the null CS (Coordinate System) means the CS is XY-M (with
 X-axis, Y-axis, the unit is meter).
 However in Fusion code, the null CS (Coordinate System) means the CS is
 "EPSG:4326" (the unit is degree).
 So if there is only a null CS MapGuide layer in the map, you'll find the
 projection for the layer is "EPSG:4326", not the correct "XY-M".
 So we need to change the WKT for null CS to be
    LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local Datum",0],UNIT["Meter",
 1],AXIS["X",EAST],AXIS["Y",NORTH]]"
 to make it "XY-M"
Ticket URL: <http://trac.osgeo.org/fusion/ticket/401>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
