[fusion-trac] #417: Base layer for MapGuide will not be shown if SingleTile is set to be true in application definition
Fusion trac_fusion at osgeo.org
Thu Nov 25 00:47:38 EST 2010
   Reporter:  sparkliu  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P3        |   Milestone:  2.2
  Component:  MapGuide  |     Version:
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 If a MapGuide map has base layer but the SingleTile is set to be true, the
 base layer will not be shown.
 It doesn't make sense to set SingleTile to be true when map has base
 layer, so we should ignore setting in applicaation definition in this
 situation.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/417>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
