[fusion-trac] #467: Display units as degrees shows incorrect
x/y values in Fusion
Fusion
trac_fusion at osgeo.org
Mon Aug 29 04:32:22 EDT 2011
#467: Display units as degrees shows incorrect x/y values in Fusion
Reporter: liuar | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: Future
Component: Core | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Comment(by liuar):
Hi Mike,
Thanks for your reply.
The wkt I got from MapGuide is
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
the second param is 298.25722293, I think this might be the problem. I
will discuss this with our CS team and let you know the result. Great
Thanks.
Regards,[[BR]]
Arthur
Ticket URL: <http://trac.osgeo.org/fusion/ticket/467#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
