[fusion-trac] #496: There is no code injection prevention in redline name
Fusion trac_fusion at osgeo.org
Thu Dec 1 00:43:17 EST 2011
   Reporter:  liuar    |       Owner:  liuar
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 steps:[[BR]]
 1. Create a redline layer, add it to map and then edit markup[[BR]]
 2. Create a line[[BR]]
 3. Use "</abc" as its name.[[BR]]
 4. Click "Update text"[[BR]]
 [[BR]]
 Expect:[[BR]]
 "</abc" is used as label and the name in the redline list should also be
 it.[[BR]]
 Actual:[[BR]]
 "</abc" only shows as label in map. In redline list, it's empty.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/496>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
