[fusion-trac] #506: Base map check/uncheck box fails to work.
Fusion trac_fusion at osgeo.org
Tue Dec 20 01:54:08 EST 2011
   Reporter:  libr     |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P3       |   Milestone:  2.3
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:  Base map checkbox
External_id:  1437620  |       State:  New
    Browser:  All      |          Os:  All
 Base map can't switch visible/invisible,as it doesn't implemented in
 server code, so the base map should not have checkbox.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/506>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
