[fusion-trac] #433: Map tips are broken in branches/2.2
Fusion trac_fusion at osgeo.org
Mon Feb 7 11:30:28 EST 2011
   Reporter:  trevorwekel  |       Owner:  madair
       Type:  defect       |      Status:  new
   Priority:  P2           |   Milestone:  Future
  Component:  Widgets      |     Version:  2.2 - RC1
   Severity:  Major        |    Keywords:
External_id:               |       State:  New
    Browser:  All          |          Os:  All
Comment(by madair):
 Trevor,
 I found this was broken in trunk but working correctly in Fusion-2.2
 branch.  Can I get you to verify which version you are testing with?  But
 mostly checking the version of Jx that you are testing with.
 The problem is due to a change in the underlying Jx object.  With Jx2 it
 uses:
             this.mapOffset = map._oDomObj.offsets;
 whereas in Jx3 we need to use:
             this.mapOffset = map._oDomObj.getOffsets();
 and the offsets are in .x and .y properties
Ticket URL: <http://trac.osgeo.org/fusion/ticket/433#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
