[fusion-trac] #434: Projection handling problems (defs folder and not passing wkt for parsing)
Fusion trac_fusion at osgeo.org
Tue Feb 22 13:07:22 EST 2011
   Reporter:  zspitzer  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:  2.2
  Component:  MapGuide  |     Version:  2.2 - RC1
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
Comment(by madair):
 The EPSG code in LoadMap.php should in theory hold a valid EPSG code, if
 it can find one, so I would prefer that the change in logic happen further
 downstream like at lines 308-317 of MapGuide.js where the epsg code and
 wkt are parsed.  It might make sense to change the logic there so that it
 checks for a valid WKT before checking for an epsg code.
 What is the value of the EPSG code being set to in your case?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/434#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
