[fusion-trac] #434: Projection handling problems (defs folder and not passing wkt for parsing)
Fusion trac_fusion at osgeo.org
Wed Feb 23 15:58:35 EST 2011
   Reporter:  zspitzer  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:  2.2
  Component:  MapGuide  |     Version:  2.2 - RC1
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
Comment(by madair):
 Zac,
 Can you test with the attached patch please?  The change is so that
 MapGuide layers will use the WKT text first, any EPSG code returned
 second, and a LOCAL CS if there is no CS information supplied at all.  It
 also adds a n OpenLayers unit-per-inch value for "Degree" units
Ticket URL: <http://trac.osgeo.org/fusion/ticket/434#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
