[fusion-trac] #428: MapGroup problem with tiled and dynamic mapguide layers
Fusion trac_fusion at osgeo.org
Tue Jan 11 19:56:11 EST 2011
   Reporter:  zspitzer  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:  Future
  Component:  MapGuide  |     Version:  2.2 - RC1
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 I'm using Mapguide 2.2 RC2 on windows
 I am trying to combine a tiled map with a dynamic overlay,
 both the map definitions are in the same projection, from the same
 mapguide server
 The problem I am having is when I zoom or pan, the dynamic layer just
 isn't updating, the app layer doesn't come on until i toggle it off and
 then on again and then it is not updated, it gets stuck as per attached
 screenshots
 I'm using the standard mapguide template applicationDefinition with
 this as a mapgroup
 <MapGroup id="app">
          <Map>
        <Type>MapGuide</Type>
        <SingleTile>false</SingleTile>
            <Extension>
          <ResourceId>Library://base.MapDefinition</ResourceId>
        </Extension>
          </Map>
          <Map>
        <SingleTile>true</SingleTile>
            <Extension>
          <ResourceId>Library://app.MapDefinition</ResourceId>
        </Extension>
                <Options>
                        <isBaseLayer>false</isBaseLayer>
                        <useOverlay>true</useOverlay>
                </Options>
          </Map>
 </MapGroup>
 I tried this with our good old friend the sheboygan sample and had the
 same issue.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/428>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
