[fusion-trac] #471: Enhance the "MapTip" widget to disable/enable map tooltip
Fusion trac_fusion at osgeo.org
Fri Jul 29 04:24:13 EDT 2011
   Reporter:  hubu         |       Owner:  hubu
       Type:  enhancement  |      Status:  new
   Priority:  P2           |   Milestone:  2.3
  Component:  Widgets      |     Version:  2.2 - RC1
   Severity:  Major        |    Keywords:  MapTip
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 Currently in MapGuide, the client sends "QueryMapFeatures" request to get
 the tooltips every time we move the cursor.
 However, most of the requests are unnecessary and useless for the end-
 user. For example, when the user are doing measure/pan/zoom, the tooltips
 are redundant for the user.
 If we remove these unnecessary requests, we can reduce server's overload.
 This enhancement make the widget "Maptip" to be an button, so we can click
 it to enable\disable the map tooltips. Then the user has an opportunity to
 disable the map tooltip to reduce server's overload, and the user still
 can enable the tooltips again by press the button again.
 By default, the tooltip is enabled, so it won't affect the original users.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/471>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
