[fusion-trac] #465: Coordinate System transform failed for some
Projection CS
Fusion
trac_fusion at osgeo.org
Sun Jun 19 23:29:34 EDT 2011
#465: Coordinate System transform failed for some Projection CS
Reporter: liuar | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
It's a defect in Proj4js.
For example:
Transform to EPSG:4326 from following wkt, the result is always NaN
PROJCS["HARN/WI.SheboyganWI-M",GEOGCS["HARN/WI.LL",DATUM["HARN/WI",SPHEROID["GRS1980",6378137.000,298.25722210],TOWGS84[0.0000,0.0000,0.0000,0.000000,0.000000,0.000000,0.00000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse
Mercator, Wisconsin County
Variation"],PARAMETER["false_easting",79857.760],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",1.000000000000],PARAMETER["central_meridian",-87.55000000000000],PARAMETER["latitude_of_origin",43.26666666670000],PARAMETER["Average
Geoid Height (meters)",-34.0200],PARAMETER["Average Elevation (system
unit)",182.8800],UNIT["Meter",1.00000000000000]]
Ticket URL: <http://trac.osgeo.org/fusion/ticket/465>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
