[fusion-trac] #437: Tooltip support for all maps in MapGroup
Fusion
trac_fusion at osgeo.org
Wed Mar 16 00:10:25 EDT 2011
Reporter: jng | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.2
Component: Widgets | Version: 2.2 - RC1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
If you modify the Map Definitions in the sample appdef in #428 so that
each Map Definition will contain at least one Layer Definition with
tooltip information, only the tooltip information from the first map of
the MapGroup will be processed.
This is because in
[http://trac.osgeo.org/fusion/browser/branches/fusion-2.2/lib/Map.js#L1422
Line 1422 of Map.js]
getMapTip: function(oMapTips) {
//TODO send this to the correct aMap object
this.aMaps[0].getMapTip(oMapTips);
It only sends the maptip to the first map of the group, instead of all the
maps in the group.
Attached is a patch that will do the following:
1. Pass the tooltip information to each map of the group.
2. Guard against passing tooltip information to a map in the group that
has no visible layers.
3. Add an extra guard in the _display() function that disregards any
future MAP_MAPTIP_REQ_FINISHED events while the tooltip is still
displayed. This is a cheap workaround for the fact that without the guard,
the tooltip for the topmost map in the group will be shown, but will be
instantly replaced with the tooltip from the map below it.
With this patch, tooltips from both maps in the group can be displayed. If
the mouse pointer can produce a tooltip in both maps, only the tooltip for
the topmost map will be displayed.
Normal app defs (containing only one MapGuide map in a MapGroup) still
function as they were with this patch.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/437>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
