[fusion-trac] #480: Can't finish 'Select Polygon' by double click
Fusion trac_fusion at osgeo.org
Tue Nov 8 16:12:14 EST 2011
 Reporter:  liuar    |         Owner:  madair
     Type:  defect   |        Status:  closed
 Priority:  P2       |     Milestone:  2.3
Component:  Widgets  |       Version:  SVN
 Severity:  Major    |    Resolution:  fixed
 Keywords:           |   External_id:  1407182
    State:  New      |       Browser:  All
       Os:  All      |
Changes (by madair):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 fixed at rev [2451].
 It appears that the problem was caused by having more than one widget of
 the same kind in AppDef when the widgets use a path handler (the other
 widget instance remains active after a double click).  Added a unique ID
 for all widgets sp only the requested one gets activated.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/480#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
