[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Wed Nov 30 23:49:02 EST 2011
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  assigned
   Priority:  P2            |   Milestone:  2.3
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
Comment(by Christinebao):
 Hi Jng,
    Fusion should be able to know which is the current active commercial
 layer. When opening an Application Definition it has several layers, type
 is MapGuide, MapServer or general, and general type knows it's Google or
 Yahoo or Bing. Mike maybe knows more about it. Adding a type inside
 Application definition is not a good idea, as one Application Definition
 can have several commercial layers enabled, but only one is active at run
 time. So it depends on Fusion to know which is the active one.
 Thanks & regards,
 Christine
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:23>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
