[fusion-trac] #535: Support custom projections by specifying proj4js definitions inside the Application Definition
Fusion
trac_fusion at osgeo.org
Wed Aug 1 23:32:22 PDT 2012
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Currently, for any coordinate systems/epsg codes not known by the Proj4js
library, it tries to look for a javascript file
(/mapguide/fusion/lib/Proj4js/defs/EPSGXXXX.js) that probably does not
exist. The javascript file if it exists, is nothing more than just a call
to set the proj4 string in the Proj4js.defs global object
To avoid such lookups, we should have a new background widget
(CustomProjections.js?) that takes in a set of Name/Value extension
parameters which contains our custom proj4js projections. The widget's
sole purpose is to populate the Proj4js.defs global object with our custom
proj4js strings contained in the Application Definition document itself.
This way, we don't have to make such requests (or worse, trying to get the
definition from spatialreference.org. Does it still do this?) as we are
carry the custom proj4 strings inline in the Application Definition
document.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/535>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
