[fusion-trac] #434: Projection handling problems (defs folder and not passing wkt for parsing)
Fusion trac_fusion at osgeo.org
Thu Aug 2 01:59:03 PDT 2012
 Reporter:  zspitzer  |         Owner:  madair
     Type:  defect    |        Status:  reopened
 Priority:  P2        |     Milestone:  2.2
Component:  MapGuide  |       Version:  2.2 - RC1
 Severity:  Major     |    Resolution:
 Keywords:            |   External_id:
    State:  New       |       Browser:  All
       Os:  All       |
Comment(by jng):
 From my experience, driving things through WKTs is unreliable (problem
 with proj4js. I wish we could just tap into cs-map from javascript!
 Problem would be solved!)
 If we can do things via EPSG and supply the required proj4 string where
 needed to Proj4js.defs (hence the idea of #535 to avoid external lookups),
 things are usually better.
 So in this case, mapagent ConvertWktToEpsgCode says epsg is 2056
 [http://www.spatialreference.org/ref/epsg/2056/ spatialreference.org] says
 the proj4 string for this is:
 +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333 +k_0=1
 +x_0=2600000 +y_0=1200000 +ellps=bessel
 +towgs84=674.374,15.056,405.346,0,0,0,0 +units=m +no_defs
 So I'm guessing you'd have to do this somewhere in the fusion
 initialization process (or if #535 is implemented, as an CustomProjections
 widget extension property):
 Proj4js.defs["EPSG:2056"] = "+proj=somerc +lat_0=46.95240555555556
 +lon_0=7.439583333333333 +k_0=1 +x_0=2600000 +y_0=1200000 +ellps=bessel
 +towgs84=674.374,15.056,405.346,0,0,0,0 +units=m +no_defs"
 We could probably construct a csmap to proj4 lookup list to do this
 seamlessly. LoadMap.php would just consult this lookup list to setup the
 correct OpenLayers.Projection and construct the required Proj4js.defs
 entry if required.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/434#comment:9>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
