[fusion-trac] #479: mapmessage blocking mouse on map
Fusion
trac_fusion at osgeo.org
Mon Jan 9 04:27:49 EST 2012
Reporter: madair | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.3
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Comment(by wuma):
Replying to [comment:4 madair]:
> If I recall correctly, if you drag a selection or zoom box rectangle
over top of that widget you lose the mouse interaction. If this is
required you'll need to find another way to implement.
Hi Mike, The "Overview Map" and the "Navigator" have exactly the same
behavior. So maybe it's not a problem of the floating message?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/479#comment:5>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
