[fusion-trac] #518: MapGuide: External Provider widget doesn't work after refresh map by Map Widget
Fusion trac_fusion at osgeo.org
Fri Jan 20 01:10:35 EST 2012
Widget
   Reporter:  wuma     |       Owner:  Arthur Liu
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:  1437874  |       State:  New
    Browser:  All      |          Os:  All
 Steps:
 1. Open one flexible web layout with commercial layers.
 2. Click the Map Widget and select the map.
 3. Click External Provider widget.
 Results:
 In IE, nothing happened.
 In FF, commercial layers were listed in the left side but cannot be
 selected.
 Expected results:
 External widget should work as usual.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/518>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
