[fusion-trac] #523: Fusion.SimpleSelectionObject using a global variable
Fusion trac_fusion at osgeo.org
Thu May 3 16:34:30 EDT 2012
   Reporter:  mooman    |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:  Future
  Component:  MapGuide  |     Version:  SVN
   Severity:  Minor     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 The initialize method in class Fusion.SimpleSelectionObject uses the
 variable "o" which is set via eval("o=" + r.responseText) outside the
 class as a global variable. It also uses the parameter that is passed in
 (featureInfoResponse). This is inconsistent and makes that class confusing
 to use. Not to mention potential bugs.
 The fix is simple. Replace "o" with "featureInfoResponse".
 See this line:
 http://trac.osgeo.org/fusion/browser/trunk/layers/MapGuide/MapGuide.js#L1432
 This bug still exists in the trunk.
 Thank you!
Ticket URL: <http://trac.osgeo.org/fusion/ticket/523>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
