[fusion-trac] #591: Quick Plot: Map image and legend should "fit in"
Fusion trac_fusion at osgeo.org
Fri Aug 23 00:30:10 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 Currently, depending on paper size and print element configuration, the
 final plotted PDF can look out of place. The reason for this is that the
 print size determines the size of the PDF, but the image requests assume
 this to be the same for the map and legend images to request, which is not
 true.
 Instead, the plotting code should be smarter and render the print elements
 first (title, scalebar, disclaimer), and then adjust the print size as
 necessary to get a map and/or legend that fits nicely in the remaining PDF
 space
Ticket URL: <http://trac.osgeo.org/fusion/ticket/591>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
