[fusion-trac] #593: MapMenu / map switching fixes
Fusion trac_fusion at osgeo.org
Tue Aug 27 03:55:22 PDT 2013
   Reporter:  jng      |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 * MapMenu widget currently errors if the
 data.maps[i].layerOptions.projection property is not a string (it could be
 a OpenLayers.Projection)
  * MapMenu widget should check/select the active map
  * The error message "AppDef initial view is outside map maxExtent,
 resetting initialView to maxExtent" that can be thrown when switching map
 is bunk and inconsequential. Just remove the message.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/593>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
