[fusion-trac] #582: Support extra JxLib UI initialization options
Fusion trac_fusion at osgeo.org
Wed Jul 3 00:53:26 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 Currently, the ApplicationDefinition.js will create the widget instances
 and its Jx UI widget based on the widget's uiClass property. However, the
 options passed into the Jx UI widget constructor are always:
  * label
  * image
  * imageClass
  * toggle
 There should be another property like the uiClass that we can put extra
 initialization options onto that is merged with the above properties to
 form the final initialization options that is passed to the matching Jx UI
 widget constructor.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/582>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
