[fusion-trac] #585: Redline: Local staging area for drawn redlines
Fusion
trac_fusion at osgeo.org
Thu Jul 25 01:26:08 PDT 2013
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
The problem with the current redline widget is that each redline drawn
triggers a map refresh. When redlining against a heavy map, this is
somewhat undesirable behaviour.
To alleviate this problem, we should support a local staging area where
drawn redlines go. These are OpenLayers.Feature.Vector objects sit in a
OpenLayers.Layer.Vector until the user commits the whole set of features
up to be saved to the Redline feature source
This is somewhat similar to the feature [create/checkout]-edit-checkin
workflow for AutoCAD Map. The main benefit of this is improved efficiency
as the user can draw multiple redlines in succession without an automatic
refresh (unless the user pans/zooms around while drawing)
Ticket URL: <http://trac.osgeo.org/fusion/ticket/585>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
