[fusion-trac] #604: selectionLayer.getPropertyNames() not finding last property enabled in layer
Fusion trac_fusion at osgeo.org
Thu Nov 7 12:57:55 PST 2013
layer
   Reporter:  cgountanis  |       Owner:  madair
       Type:  defect      |      Status:  new
   Priority:  P2          |   Milestone:  Future
  Component:  Widgets     |     Version:  SVN
   Severity:  Major       |    Keywords:  MapGuide 2.6
External_id:              |       State:  New
    Browser:  All         |          Os:  All
 selectionLayer.getPropertyNames() not finding last property selected in
 layer.
 Replicate: Uncheck all properties on layer (visible in viewer). Hit save.
 Run selection and selectionLayer.getPropertyNames() = null. This is good.
 Check just one property, hit save. Run selection and getPropertyNames is
 still null. Select a second property visible and hit save. Run selection,
 you only get the first property shown.
 It is like the last property you add you make is skipped when using the
 Fusion API getPropertyNames() function.
 This directly affects the selection widget so it's not that hard to test.
 Just use the parcel layer in Sheboygan and only enable one visible
 property.
 Visual:
 http://i.imgur.com/SBV1LpT.png
Ticket URL: <http://trac.osgeo.org/fusion/ticket/604>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
