[fusion-trac] #584: Support legend output in PDF QuickPlot
Fusion
trac_fusion at osgeo.org
Tue Oct 15 12:43:33 PDT 2013
Reporter: jng | Owner: jng
Type: enhancement | Status: reopened
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by steveg):
* status: closed => reopened
* resolution: fixed =>
Comment:
In the 2.6 Fusion preview the legend option was added to the QuickPlot
widget, but there are some problems when you change the DPI of the plot.
As you increase the DPI, the size of the legend decreases. I've attached
two quickplot PDFs as examples.
Perhaps on line 253 of (PlotAsPDF.php) is where some of the problem
exists:
function PxToIn($px, $dpi) {
return ($px * 25.4) / $dpi;
Also, in Maestro, I've noticed under the Widget Management, when the
DefaultDPI is set, the user is not given the option to change the DPI, but
if DefaultDPI is blank then the user can choose the options. I think it
would be more appropriate to provide a default DPI to the user, but also
give the user the option to change it.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/584#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
