[fusion-trac] #594: Quick Plot: Base layer groups are always printed even though they have been turned off.
Fusion
trac_fusion at osgeo.org
Tue Sep 3 10:35:56 PDT 2013
turned off.
Reporter: bmaehler | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Core | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
By default Fusion QuickPlot prints always the first base layer of a map
even though the layer has been turned off in legend tree.[[BR]]
Also Fusion MapSave saves always the first base layer.[[BR]]
Example:[[BR]]
http://www.geoportal.hilden.de/karten/stadtkarte/
This map contains two base layer:[[BR]]
A city map (layer Stadtplan) which is the first base layer and an aerial
map (layer Luftbildkarte), the second base layer.[[BR]]
Steps to reproduce :[[BR]]
1. Turn on the layer "Luftbildkarte" and turn off the layer
"Stadtplan"[[BR]]
2. Call QuickPlot (Karte drucken -> PDF Druck)[[BR]]
3. Print the map (Button "Drucken" in Task Pane)[[BR]]
or[[BR]]
4. Call SaveMap (Karte speichern -> PNG-Format)[[BR]]
Possible cause of the problem (analysed by Jackie Ng):[[BR]]
When Fusion makes OpenLayers.Layer.MapGuide instances for each tiled layer
group, it doesn't seem to be attaching the runtime map name to these
instances. Thus when these groups are toggled on/off in the Legend,
there's no map name to identify the server-side MgMap instance where we
need to toggle these base layer groups on and off.
[[BR]]
When you do a QuickPlot, it's doing a RenderMap of the MgMap instance
which is not aware that the base layer group has been turned off, so
that's probably why those layers are still drawn in a Quick Plot or any
Rendering Service API.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/594>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
