[fusion-trac] #596: Disable tilt in Google Layers
Fusion trac_fusion at osgeo.org
Tue Sep 10 20:10:23 PDT 2013
   Reporter:  jng      |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 If you view a Flexible Layout with Google Layers turned on, chances are
 your map data will be displaced from the underlying Google data at lower
 levels due the Google layer being tilted.
 Checking in a [http://trac.osgeo.org/openlayers/ticket/3615 patched
 version of OpenLayers/Layer/Google/v3.js that disables this feature] will
 fix this issue.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/596>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
