[fusion-users] Fusion Questions
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Wed Jul 16 08:03:13 EDT 2008
Ok, well I did manage to get the Navigator scale to be correct. It ended
up being a matter of making sure I had no MAXSCALE parameters in my map
file that were beyond what I set the overall MAXSCALE set to. It was a
little bit of a pain to have to go through and modify so many layers but
at least I got what I was after.
I'll try to see what movement of the Navigator can be accomplished with
just CSS. It's odd though because there is already automatically
generated CSS on the Navigator that positions it where it's at.
As far as the independent units for widgets, I did try using the <Units>
tag inside <Extension> but that didn't give me any different results.
The reason I asked this was that the MapGuide/Fusion example does have
this for the CursorPosition & ViewSize widgets. I want the
CursorPosition widget to be in decimal degrees (which I have already),
and the ViewSize widget to be in miles.
Thanks.
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Tuesday, July 15, 2008 6:36 PM
> To: Nolte, Tim
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] Fusion Questions
> * The max scale of the navigator widget should be calculated
> from the
> extent defined in the map file.  But the navigator is
> currently poorly
> implemented so it is quite possibly not working or difficult to work
> with.
> * you should be able to use css to reposition the navigator
> * I don't think you can set independent units for widgets but if you
> can, then you would add <Units>meters</Units> (with the appropriate
> unit) to the widget's <Extension> in the ApplicationDefinition.xml
> Cheers
> Paul
> On 15-Jul-08, at 4:39 PM, Nolte, Tim wrote:
> > Have a few questions:
> > 1. How do you changing the max scale/zoom of the Navigator widget?
> > 2. How do you set the navigator to be on the right side of
> the map by
> > default?
> > 3. How do you set different independent units for the
> CursorPosition &
> > ViewSize widgets?
> > Thanks!
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS:    616-706-2438
> > Fax:    616-554-6484
> > fusion-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://www.dmsolutions.ca/
More information about the fusion-users mailing list
