[fusion-users] MapServer + Fusion
Jason Fournier jfournier at dmsolutions.ca
Tue Jul 29 21:38:11 EDT 2008
Hey Jeff,
I think you're right - this works for me in a MapFile:
WEB
  METADATA
    "legend_title"  "CUSTOM MAP NAME"
  END
END
That replaces the 'new node' label.  To replace the one above that I think
you can edit the strings file(s).
Best regards,
Jason
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Tuesday, July 29, 2008 6:57 PM
To: fusion-users
Subject: Re: [fusion-users] MapServer + Fusion
Can someone refresh my memory for what metadata item is required to
change the root folder name displayed in the legend?  (for example if
you use the gmap mapfile you will see "new node" at the top of the
legend tree by default, instead of a pretty map title)  For the life
of me I could have sworn there was a special metadata item for
this...but I can't remember!
thanks.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-Jul-08, at 2:04 PM, Paul Spencer wrote:
> Tim,
> there is a little bit of layer metadata that you can use to control
> how things appear in the legend.
> "displayInLegend" "true|false"
> By default, all layers are shown in the legend.  If set to false, it
> will hide the layer in the legend
> "expandInLegend" "true|false"
> By default, all classified layers will show a sub-branch in the
> legend with all the classes.  If set to false then the sub-branch is
> initially collapsed
> "legendLabel" "string value"
> By default, the layer's NAME value is used in the legend.  If this
> metadata is set, then the value will be used in the legend instead.
> "selectable" "true|false"
> By default, layers are not 'selectable' using the select widget.  If
> this is set to 'true' then the layer will be considered 'selectable'
> so the select widget will be enabled when this layer is selected in
> the legend.
> The legend will create folders for each group and put the
> appropriate layers in those groups.  The groups respond to the
> following metadata in the first LAYER object in the group (first
> layer to use the group name)
> "groupLegendLabel" "string value"
> By default, the group name is used as the legend label.  If this
> metadata is set then the value will be used instead of the group name.
> "groupDisplayInLegend" "true|false"
> By default, all groups are displayed in the legend.  Setting this to
> false will hide the group in the legend (and all layers that are
> part of that group too).
> "groupExpandInLegend" "true|false"
> By default, groups initially start expanded to show the layers in
> that group.  Setting this to false will start the group off
> 'collapsed'.
> Cheers
> Paul
> On 11-Jul-08, at 12:37 PM, Nolte, Tim wrote:
>> One issue that I have, and I found out why, is that my separate
>> layers
>> end up getting stuck together. (those that are in the same group).
>> What
>> I found out was that those layers that I have named like "Johnson
>> City"
>> aren't accessed correctly and able to be independently turned off.
>> However, if I name the layer "JohnsonCity" with no spaces in the name
>> then it works fine. The things about this is that what gets
>> displayed in
>> the Legend is that name and I don't want crapping looking layer
>> titles.
>> Also, something that I haven't figured out is how to completely hide
>> certain layers from the legend that I use for dynamic purposes, that
>> shouldn't be showing by default. Another problem I seem to have is
>> that
>> my legend icons don't all seem to be showing up correctly. Now this
>> could be an issue with the version of UMN MapServer that I'm using. I
>> did have to do some custom things to get these working in my other
>> mapping framework.
>> - Tim
>> Timothy J Nolte - tnolte at ilpcs.com
>> Network Planning Engineer
>> iPCS Wireless, Inc.
>> 4717 Broadmoor Ave, Suite G
>> Kentwood, MI 49512
>> Office: 616-656-5163
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> Web: www.ipcswirelessinc.com
>>> From: fusion-users-bounces at lists.osgeo.org
>>> Jason Fournier
>>> Sent: Friday, July 11, 2008 10:08 AM
>>> To: fusion-users at lists.osgeo.org
>>> Subject: RE: [fusion-users] MapServer + Fusion
>>> Hi Tim,
>>>> From my understanding you should not have to do too much
>>> tweaking of your
>>> MapFile to get it to work properly with Fusion.  Certain widgets
>>> will
>>> require certain aspects of the MapFile to be present but you
>>> should be able
>>> to get a usable map without having to populate the MapFile
>>> with extraneous
>>> information.  What specifically are some of the issues you
>>> are witnessing?
>>> Jason
>>> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte,
>>> Tim
>>> Sent: Thursday, July 10, 2008 3:29 PM
>>> Subject: [fusion-users] MapServer + Fusion
>>> So was able to get something working by using files found under
>>> fusion->templates->mapserver->standard for me use as samples.
>>> I was able
>>> to get the gmap demo data working and even my own current Production
>>> MapServer .map file. There are a lot of strange issues that
>>> make it seem
>>> as though I'm going to need to make a new .map file that is tuned
>>> for
>>> Fusion. I'm going to have to do some reading. Off hand, does
>>> anyone have
>>> any pointers? I'm thinking that I'm going to have to add a
>>> bunch of meta
>>> data for this to work correctly. Is Fusion using my MapServer
>>> install/mapfile as a WMS or WFS source?
>>> - Tim
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
