[fusion-users] Checking layers in the legend not working correctly
Bernhard Schneider bernhard.schneider at ilu.ch
Mon Jun 9 02:29:25 EDT 2008
Hi everyone,
After starting the Fusion map application that I'm currently working
at, the visibility of the map layers and the status in the legend are
in synch, that is, all map layers that are checked in the legend and
only these are visible in the map. However, if I uncheck a map layer,
it remains visible in the map, if I check it again, it's gone from the
map only to reappear when I uncheck it. I can reproduce this behaviour
with all map layers and map groups.
I tried to track the problem down, and it may be in the functions
show() and hide() of Fusion.Maps.MapServer.Layer and
Fusion.Maps.MapServer.Group. (I'm using MapServer 5.something.) In the
four functions, redrawing of the map is triggered through
showLayer(..), hideLayer(..) and showGroup(..), hideGroup(..),
respectively. Then, statements that change the value of the visibility
flag follow. I suspect that the latter statement should occur before
(!) that calls showLayer(..), etc. I tested it, and it fixed the
problem. Am I missing something?
Should I post this to the Fusion-Dev list?
Bernhard
More information about the fusion-users mailing list
