[fusion-users] Layer status
Paul Deschamps
pdeschamps at dmsolutions.ca
Wed Jun 18 15:13:50 EDT 2008
I though I would give a little walk through on how to add events in Fusion
Widgets for those of you who want to "extend" events in some of the widgets.
For this example lets use the legend widget.
First add the new event obj, before the "OpenLayers.Class(Fusion.Widget"
// CODE BLOCK [legend.js] ---------------------------------
Fusion.Event.LEGEND_LAYER_VIS_ON = Fusion.Event.lastEventId++;
Fusion.Event.LEGEND_LAYER_VIS_OFF = Fusion.Event.lastEventId++;
Fusion.Widget.Legend = OpenLayers.Class(Fusion.Widget, {
//END CODE BLOCK ---------------
Next bind this event to the init section of the class around line 70:
//console.log('Legend.initialize');
Fusion.Widget.prototype.initialize.apply(this, [widgetTag, true]);
var json = widgetTag.extension;
this.registerEventID(Fusion.Event.LEGEND_LAYER_VIS_ON);
this.registerEventID(Fusion.Event.LEGEND_LAYER_VIS_OFF);
Now trigger the event in the legend class, for this we want to trigger it
when the layer checkbox is clicked: around line 499:
stateChanged: function(obj) {
if (obj.legend && obj.legend.checkBox) {
if (obj.legend.checkBox.checked) {
this.triggerEvent(Fusion.Event.LEGEND_LAYER_VIS_ON, obj);
obj.show();
} else {
this.triggerEvent(Fusion.Event.LEGEND_LAYER_VIS_OFF, obj);
obj.hide();
Now in your supporting js for the Fusion application you should have a
function called when fusion is initialized. inside this function you will
need to registerForEvent on the legend widget to handle this trigger. :
// CODE BLOCK ---------------------------------
var legend = Fusion.getWidgetsByType('Legend');
if (legend.length > 0) { // 0 is the first legend widget.
legend[0].registerForEvent(Fusion.Event.LEGEND_LAYER_VIS_ON,
layerON);
legend[0].registerForEvent(Fusion.Event.LEGEND_LAYER_VIS_OFF,
layerOFF);
// END CODE BLOCK ---------------------------------
and finally add your layerON and layerOff functions:
function layerON(obj,resp){
console.dir(resp);
function layerOFF(obj,resp){
console.dir(resp);
That's it you should see the object passed back from the widget to the
application.
Hope this helps.
Cheers
Paul D.
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080618/13c9b7b8/attachment.html
More information about the fusion-users
