[fusion-users] Implementing Fusios
Jason Birch Jason.Birch at nanaimo.ca
Fri May 2 13:57:35 EDT 2008
The templates that are distributed with MapGuide do that by passing the
parameter ApplicationDefinition.  Have a look at the links at the bottom
of this page:
http://mapguide.osgeo.org/download/releases/2.0.x-samples
If you are using filesystem ApplicationDefinitions (rather than
"flexible templates" stored in MapGuide's repository), you can pass an
alternate filename (which is treated as a relative URL) or complete URL
rather than a Library reference.
https://trac.osgeo.org/fusion/wiki/Cookbook/General/LaunchOptions
And the code if you're interested in how it works:
http://trac.osgeo.org/fusion/browser/trunk/lib/fusion.js#l235
http://trac.osgeo.org/fusion/browser/trunk/lib/ApplicationDefinition.js#
l117
Jason
-----Original Message-----
Subject: Re: [fusion-users] Implementing Fusios
Based on your description then, I could have
ApplicationDefintion_App1.xml,
ApplicationDefintion_App2.xml, ApplicationDefintion_App3.xml, etcc. all
calling a single fusion template.  Obviously I need to learn more about
how
Fusion works  ;-)   I've got some work to do...
More information about the fusion-users mailing list
