[fusion-users] How to map.getSelection(). Ps.: Are you receiving my text message?
Sapucaia sapucaiatotal at gmail.com
Sat May 3 08:25:38 EDT 2008
Hi Alan, thanks for the qick reply and sorry for the double post!
I am using MapServer
On Fri, May 2, 2008 at 10:47 PM, Alan Boudreault <aboudreault at mapgears.com>
wrote:
> Hi Vitor,
> First, yes.. we have received your message :)
> About your question. It's always a good thing to tell us what is the
> cartographic web software (MapGuide and MapServer) that you use. Some parts
> of Fusion will depends of this software. Let's me know what part of Fuson
> that you use and i will try to help you.
> regards,
> Alan
> Sapucaia wrote:
>> Hi list!
>> I've sent this message a week ago, but I'm not sure if you recieved the
>> hole message (message body).
>> So, I am sending one more time. Please, at least reply me a confirmation
>> First of all, I am Vitor Fortunato, from Brazil, and I am developing an
>> application based on Fusion as my last work for graduation (monography). So
>> I decided to bring more features to Fusion.
>> I need some directions to use the method map.getSelection(callback,
>> layers, startcount).
>> After select some features in the map, am I able to call this method and
>> return all selected features (ids) and layers names?
>> My point is to do an Attribute Table, that persists in PostGIS.
>> I've started a new widget and I want to get the selected features ids and
>> layers names of each feature after select some features and execute the
>> button that call the Attribute Table.
>> My widget is attached in this mail. Note that I am just starting to use
>> Fusion and some code may be incorrect.
>  This is the first version that look just for the active layer to make the
>> grid.
>> The file:
>> http://lists.osgeo.org/pipermail/fusion-users/attachments/20080427/1214aa04/AttTable-0001.js
>> Thanks in advance!
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Alan Boudreault
> Mapgears
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080503/5201ed94/attachment.html
More information about the fusion-users mailing list
